Hi there,
Just came across an annoying problem with Simplify 3D V5.01.
I use several types of printers which also have different sized print platforms.
For each printer I have listed several processes which of course each have their respective settings as needed for that particular printer.
I have now noticed that when I have model oriented in the center of the printbed on one (larger) printer and then switch the process, thje model view of the printer in the window DOES NOT CHANGE according to the new build platform (V4 did this perfectly).
Even when I use the 'Center All Models' button, the position stays the same. But when I then slice the model and note the respective X and Y-axis coordinates, it is still showing the old settings of the previous (larger) printer.
The result is that the printer will start printing with the model offset to the left side of the printbed.
PLEASE FIX THIS !!
