davide1976italy
Movement speed colors
Hi there,
there's a way to change the scale of color movements ?
What I would like to see is something like this :
To do that I need to change manually the X/Y Axis Movement Speed, the Z Axis Movement Speed setting to the same primary travel speed and remove (or comment) all G1 and G0 movements inside 'Scripts'
If I don't do that what I see is that :
Davide
Re: Movement speed colors
Are your movement speeds that much faster than the regular printing speeds? I think on most printers they are only around 2-3x faster, so usually there's still plenty of color left for the regular print movements.
I don't know of a way to adjust the color scale right now, but that could be a good suggestion to request on the Feature Requests section of the forum to see if other users are interested!
davide1976italy
Hi S3D-Jason,
thank you for reply, our machine travels is 1000x1000x1500 and is equipped with 3 linear motor axis that reach 1 m/s, that's why the travel speed is higher then standard machine.
It would be very appreciated if developer give us the option to set up a fixed color scale inside configuration panel, in this way could be easy to understand the problems..
Davide
You are welcome to add this as a request in the Feature Request subforum. That way we can see how many other users would be interested in the same change.
billyd
S3D-Jason wrote: Thu Mar 09, 2023 10:11 am You are welcome to add this as a request in the Feature Request subforum. That way we can see how many other users would be interested in the same change.
To be honest I would prefer S3D decides which features to add rather than an online popularity contest. You should know better than random internet users what ideas have the most merit.
