I've tried to print two separate models over wifi to my connected Qidi X-Pro printer. I run an Eero wifi mesh network. The printer is about 6 feet from the router. On both occasions, the printer errors out with:
Illegal gcode in line:xxxx, P_4, T_10470103!Code: Select all
Illegal gcode n line: xxxx, P_4, T_10470000!Has anyone had similar issues? Have you resolved them?
