Custom Infill Angles
Posted: Mon Mar 13, 2023 8:26 am
Plain and simple: The new "Internal Pattern Rotation" is NOT a sufficient replacement for the previously available custom infill angles.
We can no longer adjust infill angles per layer. Leaving me unable to strengthen my parts per layer / per feature based on the infill angle.
I also used to create custom infill patterns by using different infill angles, which is no longer possible. For example, rotating the wiggle pattern by 90 degrees would result in a brick-looking infill pattern. Not possible anymore With this, I can no longer specify if I would like to include all angles per layer or not either.
Please bring this feature back.
