fredrik_wendt
Degradation: v5.0.0 ignore holes, 5.0.2 even worse
I have a fairly simple model where the holes disappear when I slice it. I've never had this happen with version 4.x.
The model: https://tmp-files-wendt.s3.eu-north-1.a ... unt-v2.stl
Problem in version 5.0.0:
https://photos.app.goo.gl/33EeYqVMNvC3ikpG6
Problem in version 5.0.2:
https://photos.app.goo.gl/bSGcgniTgkxV5S6XA
Re: Degradation: v5.0.0 ignore holes, 5.0.2 even worse
Go to Mesh > Separate Connected Surfaces and then it will slice correctly. It looks like the tabs were never properly joined with the body (it's easy to see when you turn on the wireframe view).
