Interesting problem I can't figure out?? prints solid even with 0 infill ??
Posted: Sun Mar 26, 2023 3:01 pm
by nerys
I have this one model. for some reason it refuses to slice it with infill. it makes it "SOLID" 100% infill no matter what I set the infill density too. the other 3 parts print fine but this one part (process 4) refuses to obey my commands. I can't figure out why.
Any ideas? (factory attached) very strange never had a model do this before. I even set it to merge and set the infill to 0% and it still does it 100%
I have dense infill turned off and adaptive turned off.
Its something to do with my Q5 Profile ??? when I slice in my CR6SE profile it slices fine but even when I slice it by itself in my Q5 profile its "solid" but ONLY this part. the other parts slice fine.
I figure I Must have some setting enabled or something but I sure can't figure out what. and here is the crazy part and why I think its a "bug"
Process 3 works fine 3 perms 25% infill. slices perfectly. I delete process 4. then I duplicate the perfectly working process 3 and the ONLY change I make to the duplicate is to assign it to model 4 and whammo. won't slice properly. NO CHANGES MADE other than to assign the copy of working process 3 to model 4 (the tall skinny screw)
Re: Interesting problem I can't figure out?? prints solid even with 0 infill ??
Posted: Tue Mar 28, 2023 7:24 am
by KOPrinting
Under infill, try changing your Solid Infill Threshold Area to Zero.
Posted: Wed Mar 29, 2023 6:42 am
by nerys
that does not make any sense. I am commanding "0" infill and its filling it with 100% infill.
and when I slice in another profile it slices FINE. its only THAT object for some reason it does this too and only in that profile.
Posted: Wed Mar 29, 2023 8:16 am
by KOPrinting
nerys wrote: ↑Wed Mar 29, 2023 6:42 am that does not make any sense. I am commanding "0" infill and its filling it with 100% infill.
It's filling it with Solid infill as opposed to regular infill because your part is smaller than the threshold. When I change the solid infill threshold area to "0", the part slices with 0 percent regular infill.
Posted: Wed Mar 29, 2023 7:30 pm
by nerys
ahhhhhh ok i get it. thank you!
