New Infill Patterns
Posted: Sat May 06, 2023 1:15 pm
by Johnm
There is the new Aligned Infill Pattern. I can't find any information on this new Pattern. Maybe it is supposed to be simple enough that no explanation is required. I would like a video that explains the new Changes/feature in the Infill section. I wondered if I have to select the infill pattern then the pattern angle to print.
Re: New Infill Patterns
Posted: Mon May 08, 2023 8:54 am
by S3D-Jason
The aligned pattern is actually the most simple pattern of all. It just prints lines in a single direction.
As with all the patterns, you can change the "infill pattern rotation" setting if you want to adjust the angle of the pattern.
