Hi all,
I might figure this out before I get a response but here is my issue or Question. I am designing a speaker port tube. Which is basically a flared out hollow round tube. I have printed this in the vertical direction in Vase mode. Works GREAT; comes out perfect. I now want to print a port tube with a 1mm thin flat bottom piece in the center of the tube. I have tried to print this vertically and when it gets to the flat piece the layers don't bond together and print as a solid bottom or round piece. It is not a Under extrusion nozzle issue. I know that much. It is either trying to print on supports or the Orientation of my part.
Now, I have tried to print this on its side horizontal orientation and then the round flat piece, which is now in the Vertical printing order prints perfect but the outer port tube does not print correctly. So should I print this at a 45 degree angle in order to print correctly? Or something else.
Thank You in Advance for any help you can give me!!!
