opy01
Issues with slicing
I use a Diamond Full Color nozzle (5 in 1 out) with each nozzle using its own process. Everything worked ok on 5.0.2 but now I am having major slicing issues on 5.1.0. All settings are the same on both versions as far as I can tell.
Not sure if the images will show or not, but I will try to post them
This is 5.1.0
This is 5.0.2
Re: Issues with slicing
Can you post the factory file? It's hard to give suggestions otherwise.
opy01
Max size is 3mb but this factory file is 12 mb
