Snapmaker Artisan not in configuration assistant
Posted: Fri May 12, 2023 10:05 am
The releases notes states the Snapmaker Artisan is added to the supported printers, but when running the assistant the only available options are:
- Snapmaker 2.0
- Snapmaker 3D Printer
- Snapmaker J1
Even the compatibility checker on the website says the artisan is fully supported and it says that, if the printer is not in the configuration tool, I need to update to the latest (I did), or contact the support directly and there is a provided link "contact us", which points me back to compatibility checker. You need to choose "Other" where you will have already filled in the reason for contact and the printer.
- Snapmaker 2.0
- Snapmaker J1
