zemlin
[FIXED] Print Infill Before Perimeters generates no perimeters
Factory File Attached.
Thought I'd try printing infill before perimeters to eliminate ooze zits on long travel moves.
If I select that option on the LAYERS tab, S3D 5.1 doesn't generate any perimeters, only the single extrusion fill on this model. It does not have any standard infill.
PrintInfillBeforePerimeters.zip
(2.84 MiB) Downloaded 143 times
3dbybrunolopes
Re: Print Infill Before Perimeters generates no perimeters
I can confirm that...however not a feature that I used before, is definitely a bug!
This issue was fixed in our latest Version 5.1.1 release. I can confirm that the attached factory file now slices correctly in that release.
Thank you for reporting the issue! You can see the other fixes included in V5.1.1 at the link below:
https://www.simplify3d.com/products/sim ... ase-notes/
