2 Bugs found - grouping process does not take model selection changes
Posted: Mon May 15, 2023 2:32 pm
Place one model on the bed. make it multi process. in my example I needed 6 processes
now I want to print 4 of these in different orientations to take advantage of co extrusion color change effects. also wanted sequential (vase mode)
so I grouped the 6 processes together into one group.
First bug. when you "copy and paste" a grouped set of process the grouping is broken, they paste as individual processes instead of as a second set of grouped processes ie Group 2 Group 3 etc..
I did this 2 more times creating 4 groups of 6 processes each I have to manually regroup each set.
I then duplicated the flower 4 times. rotating each one 90' for effect and positioned appropriately for sequential printing
Second Bug
When you select a group and change model selection. it does not work. it ONLY changes the model selection for the first process in the group. processes 2-5 retain the default processes in this case all of them.
you now have to expand each grouped set of processes and edit each individual process to alter the model selection. so I had to do this 18 times.
Third bug. maybe not a bug might be a consequence of the other 2 ?? Variable Settings does not function in this configuration (1 model with a group of processes)
When I try to use variable settings and select "different settings for each model" the screen is not alterable. it will not permit me to increase the number past 1. it shows me "group 1 and my model below this in tree formation" but won't let me duplicate.
Factory file attached before I went through and made the 18 corrections.
Second Bug
