[FIXED] V5.1 crashes, MacOS 12.6.5
Posted: Tue May 16, 2023 4:50 pm
by waterbornewarrio
I haven't really experienced crashes previously. I use 4 processes for these parts - bottom, bottom-2, diaphragm, top. Making some changes to the processes -layers, perimeters, infills, etc - and wasn't having a problem with one model (4inch...). But then removed that and tried a different model (6inch...) and started experiencing crashes. Went back to the first model and had a few more crashes, but overall seems like it's choking on the 2nd more often. Tried replicating this in v5.02 and no crashes.
Re: V5.1 crashes, MacOS 12.6.5
Posted: Wed May 17, 2023 3:31 pm
by VTI
I downloaded your profiles and tried to open them.
I have tried to slice them, play with some parameter, but it is working on my Mac well (S3D v5.1).
Could you describe your workflow so I can test it for you on my Mac aswell to reproduce it?
(I am using Mac Mini M1, OSX Ventura 13.3.1)
BTW: Simplify3D team - manipulation with sliced view is terribly slow...
Regards
Vaclav
Posted: Thu May 18, 2023 3:06 am
by bolsoncerrado
This one has been the WEIRDEST crash so far but I'm always doing the same: opening .factory, changing profile to the most recent one and PERHAPS editting some supports or moving pieces around the bed.
This time, it crashed when I clicked the move object icon!!
Translated Report (Full Report Below)
Process: Simplify3D [1187]
Path: /Applications/3D/*/Simplify3D.app/Contents/MacOS/Simplify3D
Identifier: com.simplify3d.S3D-Software-V5
Version: 5.1.0 (???)
Code Type: ARM-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2023-05-18 09:04:32.8656 +0200
OS Version: macOS 13.3.1 (22E772610a)
Report Version: 12
Anonymous UUID: 41F4FDAA-DA47-995E-55D7-DC00BCEA34BE
Time Awake Since Boot: 2200 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000000000b8
Exception Codes: 0x0000000000000001, 0x00000000000000b8
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [1187]
VM Region Info: 0xb8 is not in any region. Bytes before following region: 105554055790408
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
MALLOC_NANO 600038000000-600040000000 [128.0M] rw-/rwx SM=PRV
Kernel Triage:
VM - (arg = 0x0) pmap_enter retried due to resource shortage
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 Simplify3D 0x1016c0c7c 0x1000bc000 + 23088252
1 Simplify3D 0x1016c4c84 0x1000bc000 + 23104644
2 Simplify3D 0x10058f82c 0x1000bc000 + 5060652
3 Simplify3D 0x10075fe7c 0x1000bc000 + 6962812
4 Simplify3D 0x10074f120 0x1000bc000 + 6893856
5 Simplify3D 0x100744a6c 0x1000bc000 + 6851180
6 Simplify3D 0x1016c30c4 0x1000bc000 + 23097540
7 Simplify3D 0x10072b088 0x1000bc000 + 6746248
8 Simplify3D 0x10072a614 0x1000bc000 + 6743572
9 Simplify3D 0x1016c30c4 0x1000bc000 + 23097540
10 Simplify3D 0x1007ed928 0x1000bc000 + 7543080
11 Simplify3D 0x100192568 0x1000bc000 + 877928
12 Simplify3D 0x1016c30c4 0x1000bc000 + 23097540
13 Simplify3D 0x100b5bf10 0x1000bc000 + 11140880
14 Simplify3D 0x100c0f2c4 0x1000bc000 + 11875012
15 Simplify3D 0x100c102c4 0x1000bc000 + 11879108
16 Simplify3D 0x100cccb50 0x1000bc000 + 12651344
17 Simplify3D 0x100b94fb4 0x1000bc000 + 11374516
18 Simplify3D 0x100ccd164 0x1000bc000 + 12652900
19 Simplify3D 0x100b63de4 0x1000bc000 + 11173348
20 Simplify3D 0x100b66764 0x1000bc000 + 11183972
21 Simplify3D 0x10169d8e0 0x1000bc000 + 22943968
22 Simplify3D 0x100b64680 0x1000bc000 + 11175552
23 Simplify3D 0x100bad858 0x1000bc000 + 11475032
24 Simplify3D 0x100bac8f8 0x1000bc000 + 11471096
25 Simplify3D 0x100b63de4 0x1000bc000 + 11173348
26 Simplify3D 0x100b650f4 0x1000bc000 + 11178228
27 Simplify3D 0x10169d8e0 0x1000bc000 + 22943968
28 Simplify3D 0x100e3a378 0x1000bc000 + 14148472
29 Simplify3D 0x100e28954 0x1000bc000 + 14076244
30 Simplify3D 0x1008a3578 0x1000bc000 + 8287608
31 CoreFoundation 0x18d3f2710 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 28
32 CoreFoundation 0x18d3f26a4 __CFRunLoopDoSource0 + 176
33 CoreFoundation 0x18d3f2414 __CFRunLoopDoSources0 + 244
34 CoreFoundation 0x18d3f101c __CFRunLoopRun + 828
35 CoreFoundation 0x18d3f058c CFRunLoopRunSpecific + 612
36 HIToolbox 0x196c25df4 RunCurrentEventLoopInMode + 292
37 HIToolbox 0x196c25a84 ReceiveNextEventCommon + 220
38 HIToolbox 0x196c25988 _BlockUntilNextEventMatchingListInModeWithFilter + 76
39 AppKit 0x19060ff58 _DPSNextEvent + 636
40 AppKit 0x19060f0f4 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 716
41 AppKit 0x190603558 -[NSApplication run] + 464
42 Simplify3D 0x1008a2564 0x1000bc000 + 8283492
43 Simplify3D 0x10169a534 0x1000bc000 + 22930740
44 Simplify3D 0x10169df34 0x1000bc000 + 22945588
45 Simplify3D 0x1007d3e68 0x1000bc000 + 7437928
46 dyld 0x18cfbbf28 start + 2236
Thread 1:: Qt bearer thread
0 libsystem_kernel.dylib 0x18d2dc834 poll + 8
1 Simplify3D 0x1016e72dc 0x1000bc000 + 23245532
2 Simplify3D 0x1016e89d8 0x1000bc000 + 23251416
4 Simplify3D 0x101554b6c 0x1000bc000 + 21597036
5 Simplify3D 0x101555838 0x1000bc000 + 21600312
6 libsystem_pthread.dylib 0x18d313fa8 _pthread_start + 148
7 libsystem_pthread.dylib 0x18d30eda0 thread_start + 8
Thread 2:: QNetworkAccessManager thread
1 Simplify3D 0x1016e7420 0x1000bc000 + 23245856
Thread 3:: com.apple.NSEventThread
Posted: Thu May 18, 2023 1:06 pm
by S3D-Jason
I tried slicing those files on my machine as well and they seemed to be working fine. Any other steps or changes you are making before slicing? Can you figure out which specific process is causing the crash?
Posted: Thu May 18, 2023 1:14 pm
by waterbornewarrio
VTI wrote: ↑Wed May 17, 2023 3:31 pm Hi,
Regards
Vaclav
Thanks for taking a look. I import a model, modify the Custom Zones for each of the 4 processes, based on the size of the model. For the "4i" model, the zones might be 0-48, 48-99, 99-102, and 102 up. Then prepare to print. The the "6i" model the zones might be 0-60, 60-149, 149-152, and 152 up. When this started I had successfully sliced the 4i model. Then removed it, imported the 6i model, modified Custom Zones, and crashes started when I sliced. Now crashes happening with both models.
Unfortunately I'm on an older Mac that won't upgrade to Ventura, so still on Monterey. Hopefully a new machine in a few months, but there seem to be issues with the newer hardware and/or OS, as well?
Posted: Thu May 18, 2023 3:42 pm
by S3D-Jason
Can you attach a factory file that only has 1 process which reproduces the crash? Part of the reason why weren't not reproducing it might be because you have so many different processes in those files and that makes it harder for us to know what exact options you are picking.
Posted: Sun May 21, 2023 2:14 pm
by VTI
waterbornewarrio wrote: ↑Thu May 18, 2023 1:14 pm
Regards
Vaclav
Hi, it is working well on my Mac, sorry - I cannot help.
BTW: I noticed that your process and cad file names contain characters that some software doesn't like. Maybe that's not the problem, but it caught my eye right away.
Good luck
Vaclav
Posted: Mon May 22, 2023 6:30 am
by bolsoncerrado
CRASH.factory
(30.51 KiB) Downloaded 664 times
What about this one? It crashes my M1 Ventura 13.4 just because Raft is enabled.
Posted: Mon May 22, 2023 1:35 pm
by VTI
bolsoncerrado wrote: ↑Mon May 22, 2023 6:30 am CRASH.factory
Hi, I tried your factory file and got the same crash :cry:
Regards
Vaclav
Posted: Tue Jun 06, 2023 7:58 am
by S3D-Jason
We just released Version 5.1.1 today which has several important bug fixes, including one that resolves the issues mentioned in this thread. I have confirmed that all of the factory files attached above now slice correctly with the latest V5.1.1.
You can see the other changes in this release at the link below:
https://www.simplify3d.com/products/sim ... ase-notes/
