Some of my parts end up with lots of short loops in areas. Was excited to see this option as it would save some time in those areas. The issue with it is that if the next move is a long traverse, it happens without a retraction and leaves a zit on the part at the other end of the travel.
I don't have a proposed solution, but that makes this feature unusable for me. I almost never have a single part on the build plate, so avoid open spaces wouldn't fix the issue. Maybe if the next move is a travel of more than X distance or force a retraction or force retraction if crossing open areas.
