Stop at Height [V5.1.0]
Posted: Sat May 20, 2023 3:46 pm
by erikzweigle
Am I blind or is start/stop at height X no longer available in V5? I don't see it in the advanced tab. What is the new recommended equivalent?
Re: Stop at Height [V5.1.0]
Posted: Mon May 22, 2023 10:04 am
by S3D-Jason
In V5, the "stop printing at height" option from V4 moved to a dedicated "Custom Zones" button at the bottom of the process settings window.
Posted: Mon May 29, 2023 4:32 am
by hendrik6073
Strange place to hide that. Had a failed print due power outage (in a 14 hour print). Had to search so long (coming from v4.x) that the print is now unrecoverble and i have to start all over :-(. Is there some kind of reference to explaine functions that are moved to places where you would not search fot them?
Posted: Tue May 30, 2023 10:11 am
by S3D-Jason
The Custom Zones menu is the only new section in the Process Settings window. All other settings should just be in one of the tabs.
If you need help locating a setting, you can always use the new search bar in the top right of the Process Settings window. Just type the name of the setting and then it will take you to the exact tab and location where that setting resides.
