5.1 multi model issue
Posted: Mon May 22, 2023 8:33 am
by jstrom
On V5.1, when duplicating a model and processes to print 2x serially (only tried 2x) of a model with a copy of the print process assigned to the second model (as per instructions), the print head seems to loose track of location and does not find the correct location to continue the printing of the model. This happened for both x and y coordinates. I had it travel between model every 8mm layer height to allow for head clearance. This works well on S3D version 4 as I used the feature regularly on that version. I have not tried it in v5.0. Tried on FlashForge Dreamer printer.
Re: 5.1 multi model issue
Posted: Mon May 22, 2023 10:20 am
by S3D-Jason
What do you mean it loses track of the location? Does the preview in S3D look correct? Is it just an issue when actually printing on the machine?
