Monotonic infill sequence?
Posted: Sat May 27, 2023 9:29 am
by ssassen
The 'monotonic infill sequence' is mentioned as a new feature for 5.1. I'm trying to find this setting but have a hard time locating it? Could anyone perhaps point me in the right direction? Thanks!
Re: Monotonic infill sequence?
Posted: Tue May 30, 2023 10:07 am
by S3D-Jason
If you type "monotonic" into the search bar in the top right of the process settings window, it will take you to the new settings. It's on the Infill tab. You just enable that checkbox and then the new feature is enabled.
Posted: Fri Jan 12, 2024 4:31 am
by yoda
Hello, in my 5.1.2. version is missing this settings. At tab INFILL is nothink about it ... how can I use it?
Posted: Fri Jan 12, 2024 12:46 pm
by S3D-Jason
I should be the checkbox at the bottom of the "Solid Layers" section on the Infill tab. It's called "Minimize direction changes (monotonic)"
