Printing over support
Posted: Mon May 29, 2023 5:17 am
Hi, I am having an issue with poor quality when printing a layer over a support. As it seems the support orientation is always parallel to the X axis, as is the fist layer when printed over a support . The layer printed directly onto the bed is oriented at 45 degrees. This causes in my prints a poorer quality, as some lines are purely bridging, falling between the support structures. rotating the object by 90 degrees might help, but is not a very comfortable solution. Is there a way to orient the first layer over a support structure also in a 45 degree angle ?
Thanks in advance for your help
Matthias
Matthias
