Live Preview Tracking not updating in 5.1.0
Posted: Thu Jun 01, 2023 2:48 pm
I can turn on Live Preview Tracking, but it does not update frequently. There is no longer a UI control to set the update interval, so I can't tweak it to see if the behavior changes. There seem to be several issues:
1. When Preview By is set to Layer, it does not update for every layer. I saw the display jump from 27 to 29.
2. The layer number / Z value in the Preview panel can get far ahead of Z value in the Machine Control Panel. I observed Z in Preview stepping up 25 seconds before Z in MCP. I realize there can be buffering in the printer, but that seems a lot. The release announcement said the coordination had been improved... seems to still be an issue.
3. When Preview By is set to Lines, it does not update very frequently. I observe that it stays at the same line number and the graphic does not update, for about 2 minutes. The Lines update does *not* seem to be related to when the Layer changes (i.e. when the Z value jumps). So at this point the Lines preview is not usable.
I'm running 5.1.0 on MacOS Ventura 13.3.1. I'm controlling a Robo3D R1+ over USB.
As others have stated in other posts, the Live Preview Tracking is an important part of our print job management, especially for manual filament changes etc.
Thank you.
Thank you.
