V5.1 crashing when raft is selected
Posted: Tue Jun 06, 2023 1:15 am
Printing a specific Model which consistently warps. So to avoid that I selected to print with raft using the default raft configuration. When I select "prepare to Print" S3d start to slice then at about 3/4 mark crashes & disappears off screen. On restart the prior print (factory file) is loaded not the current one, so I have to start layout again. If I don't select raft then everything continues OK.
I have used different raft settings with same result. I am using a PC with Win 10
