I think some of the quality issues I"ve faced have to do with over extruding. So today I've been trying to get a good extrusion multiplier for some plastic and print some tests. I keep going lower and lower. For my 1.75mm filament I've always used in the .9-1.0 range depending on the material. For the 2.85 stuff I have I'm going much much lower and I almost think I could still go lower. Something seems a little fishy that the calculations for plastic would be 30% off. I just printed a perfect flat bottom several layers with no gaps at a .65 multiplier for filament measured at 2.94mm.
Attaching factory.. maybe you can see something. That seems screwy to me though.
