How do you disable the HBP?
Posted: Sun Dec 14, 2014 11:52 am
I have a FFCX clone (PowerSpec Pro). For some prints, I need the HBP to remain disabled. I've tried setting the temp point to zero, setting it to somewhere near room temperature, or even just removing the HBP from the Temperature tab altogether. No matter what I do, it either hangs indefinitely while trying to reach the "proper" temperature, or it actually heats up a bit, often causing some uneven warping.
What is the proper way to disable the HBP entirely?
