At our last meeting we thought made to improve the surface of the top layer as we see this a possibility.
The fill is currently drawn in parallel lines that end in the perimeter shells. The promotion of the extruder but is not interrupted when changing the line which leads to the surface at a slightly pointed wobble. Would not it be possible the promotion of the extruder for this moment the offset between the lines to make and so avoid a material abundance at these points one?
Greetings Edwin
