colton3
Ubuntu Crash
Tried installing Simplify on a laptop with ubuntu 14.04 32 bit.
The first time I installed it, it worked fine. After installing the drivers for connecting my Makerbot Rep2X via USB, The program won't open. When I run the desktop shortcut the configuration assistant pops up for a few seconds (with the window contents never rendering) and then it exits.
I'm brand new to ubuntu (windows guy)
Am I missing something basic?
KeyboardWarrior
Re: Ubuntu Crash
This may be due to graphics drivers. Can you check that the graphic drivers you have are the most up-to-date for your card.
TenKOhms
Re: Ubuntu Crash
How did you install drivers on ubuntu for your printer? I was under the impression you did not need drivers for Ubuntu/Linux to communicate with most serial devices.
Try opening up the Terminal and enter the command:
cd /opt/Simplify3D-2.2.0
hit enter, and it should bring you to the correct directory then type:
sudo ./LaunchScript.sh
This *should* launch s3d if everything is installed properly. You will have to enter your password for sudo commands.
colton3
Re: Ubuntu Crash
@ KW, didn't come to mind that it could be a graphics issue, I'll check on that. However, I was able to open Simplify before and view a model.
@TenK, I tried to install makerware but was unsuccessful... I tried running the launch script directly before, makes no difference. Going to try and install makerware again.
