Printer will nonsensical way
Posted: Fri Dec 19, 2014 1:43 pm
by Edwin
I have the following problem that in some of my components bother me again and again and that comes to bear in a very particular.
The printer does not work from the component in a truly meaningful order of the lines. I have a component in which this problem occurs especially here.
The printer operation at individual islands and then travels always on the farthest opposite point of the component and works there. He does it for the whole component and it costs almost half the time to print the part because the printer always drives over the whole component of time, instead of just directly run next to print on.
With the new version, it has become a bit better, as this now makes the individual islands ready and take eight hours as needed pressure now only 6.5 hours at 50 mm / s printing speed. Simplify tells me to but only 3 hours and 9 minutes. I've tried a few settings, but made it only worse.
Is there another setting I do not know to prevent this?
Greetings Edwin
Re: Printer will nonsensical way
Posted: Fri Dec 19, 2014 4:32 pm
by dsegel
I think what your saying is that the print moves are not optimized - that the slicing engine is moving the hot end all over the place instead of taking the least-distance path. I've noticed the same thing in some cases.
One thing you can try is to change the Layer - Start Points setting, although the default is already set to optimize for fastest printing speed.
Posted: Sat Dec 20, 2014 5:05 am
by Edwin
The lockup a starting point does not resolve the problem, unfortunately, since this senseless process takes place within a layer and but I just can specify a starting point. If I wanted to do it manually, ih would require approximately 200 manual starting points per layer.
