Simplify3d 2.2.0 OS X connected to Davinci Dup 2.0J via USB, Davinci running stock firmware.
Several times over the past few days (I've only had my printer for 4 days) I've found that sending a file with multiple models will cause my printer to crash and restart. Before I dive in and attach .factory or .gcode files, wanted to know if this is a known issue - I haven't narrowed it down to complexity or size, but I find that removing models and/or removing duplicates will allow me to print. I tend to gang up my prints to make most efficient use of print time, but I find that this often cause the crash issue. However, I've also seen the issue with a single model printing multiple copies.
Is there a limit on either polygons or file size that can be sent to a Davinci Duo from Simplify3D? Note that in cases where I couldn't send from S3D I was usually successful in sending to printer using XYZWare 1.1.1 for OS X.
