Bed Leveling Wizard Question.
Posted: Tue Dec 23, 2014 3:52 pm
by rforeman
Does the Bed Leveling Wizard work with the DaVinci printer?
Re: Bed Leveling Wizard Question.
Posted: Tue Dec 23, 2014 4:23 pm
by habloIngles
Was also wondering about this, read this:
http://www.simplify3d.com/support/hardw ... vinci-1-0/
I'm almost 100% sure you need a firmware that can be manually controlled (1.1J on my da vinci 1.0) for the bed leveling wizard to work. It works for me, but I'm on a firmware that allows for manual control.
Posted: Tue Dec 23, 2014 4:31 pm
by rforeman
Yea I was wandering if anyone had tried it. I have FW 1.1.I. I may play with it tonight.
Posted: Wed Apr 29, 2015 11:04 pm
by fantome
I tried the wizard and it seemed to get rid of the Z offset I had to set in Simplify3D. Does it store a value somewhere? I only had to do minor adjustments to the bed but the 2.98mm offset had to to be reduced to zero. I like it but I don't understand what happened. Like I said, I only made minor changes to the hight of the bed during the wizard, definitely not 2.98mm. Does anybody know for sure what it does in the software?
Thanks...
Posted: Thu Apr 30, 2015 6:37 am
by JoeJ
Isn't the point of the bed leveling wizard to remove the need for using an extra Z-offset? In my mind, if you successfully level the bed using that tool, then by definition your Z-offset should be zero.
