Bug reports: some helpful suggestios
Posted: Thu Mar 14, 2013 4:08 pm
by ChairmanNow
It'd be much easier to report possible bugs if we could post images and upload files. It'd also let other users, potentially, either reproduce the issues, or point out why it might not be a bug, but simply a misconfiguration.
Can this happen?
Thanks,
CM
Re: Bug reports: some helpful suggestios
Posted: Thu Mar 14, 2013 4:18 pm
by Simplify3D
You should be able to post pictures as an attachment. When making a post click the "Upload attachment" tab right below the posting window. Choose the file you want to upload and click "Add the file". Are those options showing up for you?
Posted: Thu Mar 14, 2013 4:37 pm
by ChairmanNow
Ah. Didn't see the size limitation message before, or it didn't appear. Attachments limited to 256k.
See below for images from an earlier attempt to file a possible bug report - it'll be a good test. Preview is only showing one image, but hopefully both show up.
- bug_report_cm1.png (227.07 KiB) Viewed 6068 times
- bug_report_cm2.png (126.44 KiB) Viewed 6068 times
