Trrouble slicing one piece - walls incomplete
Posted: Fri Dec 26, 2014 7:38 pm
by dsegel
The attached stl file slices fine in Slic3r, but in S3D the side walls only extend about half way. I've tried many different settings without any luck. Any ideas?
Re: Trrouble slicing one piece - walls incomplete
Posted: Fri Dec 26, 2014 11:05 pm
by jimc
yeah sure, the walls are too thin to print. it wont print if you extrusion width is over .47mm. even if you set it to .47 though it will probably print out of spec because its still squishing 2 perimeters into a space where there is only room for 1. you gotta remember there is always an inner and outer perimeter. slic3r will actually print a single 1 wall perimeter
Posted: Sat Dec 27, 2014 12:39 am
by dsegel
Thanks, I suspected it was something like that but didn't know that Slic3r would just put in a single-width wall. I'll try it with a smaller extrusion width and see how it goes.
