Print centering Question?
Posted: Fri Dec 26, 2014 8:39 pm
by mikenmel08
I am running a Flashforge Dreamer and when i print with the right nozzle it prints directly to the center of the bed as it should........now when i print with the left extruder it offsets the print over to the left a few inches.....Is there any way to make it start the print in the center of the bed also?
Re: Print centering Question?
Posted: Sun Dec 28, 2014 11:16 am
by rovino
I had a similar issue, not off by a few inches but noticeably off.. I updated my firmware on my FFD using an older version of flash print because the 2.xx version had a bug.. then you have to connect your ffd to you computer via usb to get it updated.
heres a cut and paste of the email I was sent..
"I want to say that you should update the firmware on the old software.
Please try to follow below to try again and check whether it works.
1. Uninstall 2.1 FlashPrint software from your computer.
2. Download 1.3 FlashPrint software from here:
https://www.dropbox.com/s/ngdmhjw59slkh ... 0.exe?dl=0
3. Install 1.3 FlashPrint on your computer.
4. Plug USB cable from computer to Dreamer. But do NOT power on the printer at the moment.
5. Open FlashPrint, go to menu "Tools---Update Firmware", a new window will pop up.
6. Select firmware: dreamer_2.0.20140827.bin.
7. This step is critical which concerns whether you can succeed uploading new firmware or not.
Switch on the printer, within fraction of second, click "Rescan" button on the new window in the FlashPrint, a new Serial Port will come out, select that port and quickly click "OK" button at the bottom of the window and then click OK in the popped up information window. Four actions: rescan, select new serial port and click OK button and click OK button again, must be completed within a very short time.
8. Process bar enable and new firmware uploading will succeed.
9. If the printer can start up normally which means new firmware has been uploaded successfully, then install the new FlashPrint_2.1.20140828 on your computer. You can connect the printer to computer via USB only using the new flashprint software. "
it worked for me both extruders find the middle of the print bed now.. even though Im currently using Simplify 3D
Posted: Sun Dec 28, 2014 6:29 pm
by KeyboardWarrior
I believe this was an issue with the earlier profiles, due to the tool-head offsets of the FlashForge Dreamer. If you download version 2.2 of the software, go to Help-->Reset all settings, then reopen it and use the built-in profiles to print with the left I don't think you'll have that issue.
Posted: Sun Dec 28, 2014 8:33 pm
by mikenmel08
KeyboardWarrior wrote:I believe this was an issue with the earlier profiles, due to the tool-head offsets of the FlashForge Dreamer. If you download version 2.2 of the software, go to Help-->Reset all settings, then reopen it and use the built-in profiles to print with the left I don't think you'll have that issue.
Thanks, I will try that tomorrow.....I updated already but didn't do a reset...
Posted: Mon Dec 29, 2014 11:47 am
by jabatan
Hi! Do you have a similar solution for MAC? I tried replicating the steps above but it does not seem to be able to upgrade firmware.
Thanks.
David
Posted: Mon Dec 29, 2014 12:25 pm
by mikenmel08
That got it working properly......Thanks
