S3D on a Mac, Davinci 2.0 with Repetier firmware 0.92
I've set S3D to use "XYZPrinting Da Vinci 2.0" config via the Configuration Assistant. I've noticed that my build volume display is rectangular instead of square - apparently the config sets the X-axis to 15cm and the Y and Z axes to 20cm (actual specs are 20cm for X and Y, 15cm for Z).
When trying to change settings to correct dimensions via Preferences -> Machine -> Build Volume, the changes are initially displayed but not saved and reset to incorrect 15x20x20 cm whenever the Processes window is opened. I've tried removing prefs but the change always recurs.
