smartavionics
New addition - mouse ears
Sometimes it is beneficial when printing long thin parts lying down on the bed to give them "mouse ears" to reduce the chance of them warping. Of course, you can add the mouse ears to the design but then when it is sliced, the mouse ear is considered part of the object and so the perimeters go around the disk. Surely, it would be better if the mouse ear disks are butted onto the side of the object being printed so they can be snapped off without ripping the object's perimeter.
So the feature request is to have the ability to interactively add mouse ears to a part and when it is sliced, the mouse ears can be easily separated. Think of them as localised, circular blobs of skirt that can be positioned where required.
Cheers,
Mark
ghiom
Re: New addition - mouse ears
This is a clever idea. i follow this request :)
printbus
Consider this another vote for the mouse ears request.
TenKOhms
If I'm understanding your request correctly, I believe you're requesting something such as a brim?
Try going to the Additions tab, changing the skirt outlines to 15, then the skirt offset to 0
ghiom
not really,
Brim is everywhere around the object .
Like custom support, sometimes you don't want to have them at some places .
Mouse ears could be created at specified place like custom support .
it's more efficient .
i have a folder keep around with different size mouse ears in different thicknesses. when i need one i just grab it, drop it on the table and drag it around to where i want it and slice. there really isnt any special needed within s3d to do this. to be honest though, a while back once they fixed the skirt function so it correctly followed the base of the model i havent used the ears since. nothing wrong with the ears it i just find it easier to just set a brim. it holds the model down everywhere. if i needed something more localized i would still use them though.
smartavionics
jimc, doesn't adding a mouse ear as you describe cause the mouse ears to be merged into the main object? That's what I want to avoid so to minimise the damage to the part when the mouse ears are removed. I agree you can surround the object with a wide skirt and I have done that but it's wasteful if you only want to improve the adhesion in a localised area.
montressor
Add my vote for this feature - or alternately a library of such objects we can lay down
tenaja
+1
it didnt used to merge with the model but its been a long time since i have used one of these so i just checked and tossed an ear on the table and you are right it did merge where it altered the perimeters.
