tenaja
How to start first layer at .1um?
I have been using Slic3r, and I am new to s3d.
I zero my print head with a sheet of paper as a feeler gauge. That sets z-zero at ~100um above the table. I would like to just start printing here, rather than being required to move the table up. How do I configure it so the first layer prints at Z0.000, rather than Z0.1000mm when I have a layer height of .1mm?
Thanks.
KeyboardWarrior
Re: How to start first layer at .1um?
I think there may be an issue with units here, which would over complicate things quite a bit, since 1 um is extremely small!!!
1 micrometer (1um) = 0.001 millimeters
Traditionally, copy-paper is about .1 mm thick which is 100 um. Printing at .1 mm layer height, you could just set your layer height to .1 mm and first layer height to 100% and be set from there.
http://hypertextbook.com/facts/2001/JuliaSherlis.shtml
tenaja
Huh????
Actually, I did have a few typos in there so I fixed them. By the way, S3d tech support got back to me with the answer a few days ago. The way to do it is with gcode offsets in the gcode tab.
