kelvinr
Last Layer finish
I've just started using Simplify3D and so far so good.
I read on here that in V2.2 the facility was added to set different parameters for the top/last layer(s) to improve the surface finish.
I can't seem to find where to set this.
Any pointers?
Thanks
habloIngles
Re: Last Layer finish
I don't remember there being any updates to that option. Is there particular issues you are having with your top solid layers?
in the other tab its called solid infill underspeed. it will slow down solid layers so they print cleaner
