Mac Version Tweaks
Posted: Sun Jan 11, 2015 8:50 am
After using the Mac version for the past months, wanted to make a few suggestions to make the experience a little more enjoyable:
- Application: shouldn't close when last window is closed, app should remain running until user selects "Quit"
- FFF Settings: autofill name of active FFF settings file, currently has to be retyped every export
- Factory File Saving: honor saved state of factory file (ie: don't ask to save when closing if nothing's changed since last save)
- FFF Settings: allow attaching filament profiles to settings file (size, mfr, plastic type, color, cost, purch date, SKU#)
- Model settings window: Do not open centered - it is guaranteed to obscure part of the model this way and this is an interactive process. Why is this a non-modal dialog anyway? Input ribbon would be better UI choice.
- Manual Support Definition window - Do not open centered: it is guaranteed to obscure part of the model this way and this is an interactive process. Why is this a non-modal dialog anyway? Input ribbon would be better UI choice.
- Machine Control Panel - display all tool heads at same time or break into separate section. Current dropdown method is non-intuitive because it assumes single extruder setup
- Machine Control Button on sidebar - second click should hide Machine Control Panel window for consistency with other tools
- Manual Support Definition window - second click should hide Machine Control Panel window for consistency with other tools
- Cross Section View window - second click should hide Machine Control Panel window for consistency with other tools
- Add keyboard command to "Preview G-Code" menu option (cmd-G?)
- Add keyboard command to "Remove Model" menu option (cmd-Delete?)
- Add keyboard command to "Prepare to Print" button (cmd-P?)
- Add keyboard command to "Exit Preview Mode" button (cmd-X?)
