automatic support creation misses many areas
Posted: Tue May 28, 2013 12:19 am
by cdub
I have several parts that are essentially symmetric. When I load them into Creator and select "manually define support for material" and then select "apply based on overhang angle" only 1/2 the features seem to be supported.
It seemed like version 1.1.1 didn't have this issue, but I had only dabbled with it a bit before updating.
Re: automatic support creation misses many areas
Posted: Tue May 28, 2013 11:45 pm
by cdub
I've been dabbling with this some more tonight, and have something to add to the observation.
The support that is generated automatically has a profile somewhat like a ribbon and is pretty easy to remove.
The support that is generated with the "manual" feature is used is a closed section with perhaps a rib through it and is much more difficult to remove.
I probably wouldn't have noticed it, but I end up with both methods of support generation on the exact same model due to the issue I raised previously where support generation fails on a symmetric part.
Posted: Fri May 31, 2013 9:44 pm
by Simplify3D
The automatic support material will be generated based on the grid spacing that you define. That essentially determines how small each individual support pillar will be. If you have a particularly complex part it may need smaller pillars to accurately represent it. There is a tradeoff with performance though, so don't use too small of a grid spacing unless it's really needed. We rarely have to use anything below 3mm in our lab.
And if you having difficulty with a specific object, please post your .factory file so that we can help.
