Default extrusion multiplier .9?
Posted: Wed May 29, 2013 11:51 am
by goopyplastic
I curious why the default extrusion multiplier is .9 is this on purpose for a particular reason? that would seem to be a lot of under extruding.
Re: Default extrusion multiplier .9?
Posted: Fri May 31, 2013 10:06 pm
by Simplify3D
PLA usually requires an extrusion multiplier in the range of 0.85-0.9. ABS plastic is usually closer to 1.0-1.1. The software will actually change the extrusion multiplier based on what material you select to try to give you the best starting point possible. Different extruders can behave differently though, so it might require some slight tweaking to get the best results possible.
