Simplify3D crashed (Linux)
Posted: Thu Jan 15, 2015 3:14 am
by GoldMark
Simplify3D 2.2.1
Xubuntu 14.04 LTS 32 Bit
After installation s3D worked fine. Then i would print 3 models at once via USB after 15-20mm skirt printing stopped and system was black (no reaction) and then shut-down. After restart i could not longer print via USB from S3D (Error massage that a connection not possible). Saving the G-Code is possible via Manual Control of S3D. After some reboots i have the same behaviour.
Any hints what to do?
Best Regards
Bernhard
Re: Simplify3D crashed (Linux)
Posted: Thu Jan 15, 2015 9:23 am
by habloIngles
What specific connection error are you getting? Also have you tried this?
http://forum.simplify3d.com/viewtopic.p ... 1544#p5852
Posted: Thu Jan 15, 2015 10:13 am
by GoldMark
habloIngles wrote:What specific connection error are you getting? Also have you tried this?
When i am home from office, i will look for it. And try the mentioned solution. I will keep you update.
Posted: Thu Jan 15, 2015 12:17 pm
by GoldMark
Thank you! It seems that this was the problem.
Posted: Fri Jan 16, 2015 3:21 am
by GoldMark
I can now confirm, that the hint from habloIngles is the solution for my problem.
Dear developer team,
can you solve this problem?
You only must include at the end of the installation script, a sequence, that the user has an access to all files/devices too and not only the root.
