[ADDED] Colour tool in preview to show which extruder in use
Posted: Tue Jan 20, 2015 6:11 am
by RodLaird
There is no way to tell whether you have correctly allocated extruders in the preview - that I can see. (Advice if I have this wrong)
Setting a different colour to the tool preview (which is in any case selectably viewable) would be an immense help...
Re: Colour tool in preview to show which extruder in use
Posted: Wed Jan 21, 2015 8:25 am
by TenKOhms
you're correct, the colors in the G-Code Previewer are solely based off of print speeds
Posted: Wed Jan 21, 2015 5:20 pm
by ole_blue_moon
I second your recommendation. Print preview should include colors for both the object and support when using 2 extruders. Would help when trying to verify extruders/color switches at the proper point in the print. I find the colors shown for speed to be of minimal value at least so far, maybe later when speed of print becomes more important to me.
Posted: Mon Feb 23, 2015 9:01 pm
by RodLaird
To clarify, my suggestion is to just change the colour of the "tool" when it is visible... Not necessarily the extruded material...
Posted: Thu Jul 09, 2015 8:52 pm
by S3D-Jason
This feature was addd in version 3.0. Just select "active toolhead" coloring in the preview mode.
