Rostock Max V2 fans not turning on
Posted: Thu Jan 22, 2015 9:13 pm
by dunginhawk
So i have been using matter control for a long time, and the fans come on perfecly.
Now through S3D, i set layer 1 to 0 then layer 2 to 100...
Then dont come on... am i missing something?
thanks
Re: Rostock Max V2 fans not turning on
Posted: Fri Jan 23, 2015 10:37 am
by habloIngles
Try opening up the machine control panel (with the Rostock on and connected) send in an M106 S255 to make sure the fan turns on. This is to verify that the M106 is the right G-Code command to control the fan. If that checks out, then I would slice a model, export the G-Code and then open the G-Code file in a plain text editor (such as notepad for windows or textedit for mac) and make sure the M106 S255 command is in the file where you want it to be.
Posted: Fri Jan 23, 2015 8:55 pm
by dunginhawk
yeah, its a gcode issue... its not putting it anywhere in there... for now i can turn the fan on manually until i figure out the exact command.
thanks
Posted: Wed Jan 28, 2015 8:55 am
by dreyfusduke
Fans working fine with my Rostock Max V2 when sent to SD card. I can't get my Rostock to print from USB though.
