Settings for temperature change?
Posted: Sun Jan 25, 2015 3:00 pm
by wthierry
I have changed the temps for the materials I use, why do they not get saved when I start a print? Am I doing something crazy? I open up the options and change the defaults, but they do not appear to save.....
Re: Settings for temperature change?
Posted: Mon Jan 26, 2015 12:46 pm
by KeyboardWarrior
Under the Temperature tab after you add setpoints, are you selecting Save when closing the FFF settings window? If you change to another printer profile, then change back the defaults will be loaded back in, but that's for all settings. When you customize a profile, you can use the Export button to more permanently save your settings in a .FFF profile that can be imported whenever you'd like to.
