TenKOhms wrote:tonyno wrote:Nope. No change.
what firmware version are you running on the da vinci and what OS do you have? Also, is the problem intermittent, or everytime you try to connect to the da vinci? Do you have any screenshots of the communication log of the Machine Control Panel when it won't connect?
DaVinci firmware is 1.0.3 and I'm running Windows 8.1.
It seems to stop towards the end of the print. Here are the last several entries when a print completes...
SENT: XYZ_@3D:8
RECEIVED: WORK_PARSENT:0
RECEIVED: WORK_TIME:0
RECEIVED: EST_TIME:0
RECEIVED: ET0:171
RECEIVED: BT:86
RECEIVED: MCH_STATE:27
RECEIVED: PRN_STATE:5
RECEIVED: LANG:0
SENT: XYZ_@3D:8
RECEIVED: ET0:169
RECEIVED: BT:86
RECEIVED: LANG:0
SENT: XYZ_@3D:8
RECEIVED: ET0:167
RECEIVED: BT:86
RECEIVED: LANG:0
SENT: XYZ_@3D:8
Right now, the bed temp is 56°C and the bed just dropped. I just tried Disconnect, then, Connect, and it said it was connected. I'll wait and see if I can reconnect in a little while.
