jaln
Prevent multiple instances
Check for multiple instances of S3D when the program starts and disallow more than one.
When reactivating S3D from the Taskbar, multiple instances of S3D can be started, possibly resulting in a crash, or losing current work.
Re: Prevent multiple instances
Please don't do this! I use multiple instances to connect and manage multiple printers at the same time.
jaln
Joel,
Do you start them from the program icon or from the entry in the task bar?
The reason I said that it because you can inadvertently start instances when you just want to re-open the current instance.
I can understand deliberately running an instance though.
