Infill
Posted: Mon Jun 10, 2013 12:00 pm
by Phgeis
when building an objekt sometimes it would be nice to have an increasing higher infill towards the top, like starting with 3 solids, tan 10% infill and like the last infill layers 20 or 25 and than top 3 solid layers.
Philipp
Re: Infill
Posted: Mon Jun 10, 2013 1:03 pm
by slipshine
You can do this by using different print settings for different layers of the model.
Add another .fff file and set the layer to start printing at.
Be sure to tell the original settings to stop at the layer before.
Re: Infill
Posted: Wed Jun 12, 2013 11:25 pm
by Earsmith
Are you referring to the
Other tab
Miscellaneous Pane
Start Printing at Height xxmm
If there is a Layer option would you share?
Re: Infill
Posted: Thu Jun 13, 2013 2:54 am
by Phgeis
YES!
if the layer option exist please share if it does not exist:
Understand this post as request for future options please!
Re: Infill
Posted: Thu Jun 13, 2013 10:17 am
by kaink
You can do this already.
Import your model
Size and Arrange it.
Use the "Cross Section" tool on the Z plane to determine where you would like the change to start. We will just say 10mm for easy reference.
Add 2 Processes
Open Process #1
In the "Infill" tab set infill to 10%
In the "Other" tab check "Stop Printing at height" set the parameter to 10.00mm
Click Select Models in bottom left corner of the window.
Select the Model and hit OK.
Click Save
Open Process 2
In the "Infill" tab set infill to 25%
In the "Other" tab check "Start Printing at height" set the parameter to 10.00mm
Click Save
Any other changes you make that you want to continue through the whole print be sure to change in both.
Prepare and Preview to check your work.
