lucidpsykosis
Gcode to auto shutdown printer
I've looked around, but I'm coming up empty. Is there a way to shut down my Dreamer by Gcode, when the print is done? The less I leave this thing running during the night, the better. I did find a code modifier of M81? But I think there's more to it than just a code...any thoughts?
TenKOhms
Re: Gcode to auto shutdown printer
Solely, speculation, however, if FlashPrint has no way of doing it, I'm not sure this is quite possible. The power line has a physical rocker switch, so it would appear as though that is the only way to power it down, but could be possible though!
I agree with TenK - it probably requires hardware modifications since I don't believe the electronics have this capability by default
