Material usage for each nozzle.
Posted: Sun Feb 15, 2015 1:12 pm
by Rebekah_harper
Hiya,
I was wondering if it's possible to separate the material used along with its value per kg on the preview screen.
I use ABS and hips, different values apply. Combining them is not accurate in any shape or form.
I would be really grateful if you could add this to the next up date.
Regards
Becky
Re: Material usage for each nozzle.
Posted: Thu Mar 02, 2017 9:47 am
by Arthurist
+1 and bump.
This is important when using different (and differently priced) materials. S3D already displays different toolhead paths in different colors so I don't see why not have:
Build time: 7 hours 45 minutes
Tool 0 Filament length: 11357.0 mm
Tool 1 Filament length: 5866.0 mm
Tool 0 Plastic weight:... etc....
For now, when printing PLA+PVA support, I do a workaround: copy my process, set to right extr only (pva one), make infill, perimeters, top/bot layers, and everything unrelated to support 0, the click preview - that's my PVA usage. Subtract that from dual extruder filament usage.
-Arthur
