Build time adjustment
Posted: Sun Feb 15, 2015 1:22 pm
by Rebekah_harper
Hiya,
Is there, if any, a front end adjustment to achieve a more accurate build time.
Current print is reported to take 21hrs but when I calculate from it from time spent against % completed its 32 hrs.
If there is, could some one tell me how and what values and where to get those values.
Much appreciated
Becky.
Re: Build time adjustment
Posted: Sun Feb 15, 2015 7:17 pm
by dsegel
Because of acceleration and jerk settings in your firmware, some models will be more accurate than others. Here's a graph of estimated (X axis) vs actual (Y axis) print times for the last 75 or so prints I've done. The solid line is a linear trend line. As you can see, even if I had a correction factor to apply, it would only be accurate for models with small print times (under 3 hours).
Posted: Sun Feb 15, 2015 8:16 pm
by Rebekah_harper
Wow.
Nice graph. Gues the only solution is to calculate it from an hour into the build.
Most prints are 5hrs +
Longest, 32 hours. Although this one highlighted the issue by being off by 7hrs.
Thank you though. But if there was something to get at least closer, that would be appreciate it. :-)
Posted: Mon Feb 16, 2015 7:06 am
by JoeJ
Wow, awesome graph dsegel! I'm sure the results are also VERY machine dependent, but it's neat to see the data.
