Why won't Simplify3d 2.2.2 work on my Dreamer?
Posted: Thu Feb 19, 2015 3:20 pm
This software works great on my Replicator 2, but I can't get it to work on my dreamer. I have to go in and edit the g code so it won't tell the bot to turn the extruder heater off right after it sets the temp. Then it doesn't extrude anything when it starts the print. I think the stepper motor isn't even turning on. I don't understand gcode, so I just looked at it. Here is a copy of some of it from my file that I'm trying to fit. Please note that I am using the left extruder and it does heat up as per the LCD screen on the left side despite the comments that are in the gcode getting the tools mixed up.
Is there anything in this code that is not telling the extruder stepper motor to turn on? I don't really know what I'm looking at.
; **** FlashForge Dreamer start.gcode for ABS ****
M140 S105 ; Set the current built plate temperature
M104 S220 T1 ; Set the right extruder temperature
M104 S0 T0 ; Set the left extruder temperature
G28 ; home all axes
G1 Z100 F3300 ; ? home Z?
G1 X-110.5 Y-74 F6000 ; ? home XY?
M7 ; ? coolant A on (flood coolant)?
;M6 T0 ; wait for toolhead 0 and HBP to reach temperature
M6 T1 ; wait for toolhead 1 and HBP to reach temperature
; Note that in the next line A = Right Tool
; B = Left Tool
; 100 = ABS
; 80 = PLA
; 20 = NOT USED
; What is this for? The extruder spetmoter power?
; It's probably the fan speed
; 100 = full speed.
M907 X100 Y100 Z40 A20 B100 ; ? Set digital trimpot motor current using axis codes ????
G1 Z0.6 F3300 ; Move to Z 0.6
; set feed rate to 3300
G4 P2000 ; ? Dwel P?
M106 ; Fan On
M108 T1 ; We always default to tool head 0
G1 E-1 F1200
G1 Z0.18 F1200
; layer 1, Z = 0.18
M108 T0
M135 T0
Thank you
G28 ; home all axes
; B = Left Tool
; 100 = ABS
; 80 = PLA
; 20 = NOT USED
; 100 = full speed.
M106 ; Fan On
G1 E-1 F1200
G1 Z0.18 F1200
; layer 1, Z = 0.18
M108 T0
M135 T0
Thank you
