Top Layer
Posted: Fri Feb 20, 2015 2:40 pm
by mikeysmailbox
Hi
Is there a setting to make the top layer smooth and/or have the layer start from one side and end at the other to get a better top layer?
Mike
Re: Top Layer
Posted: Sat Feb 21, 2015 5:11 am
by JoeJ
The biggest thing that has helped me is slowing down the speed at which it prints the top layers. Look in the Other tab, setting called "Solid infill underspeed". I use a value around 50-60% and it helps a lot.
My rectilinear infill already starts at one side and works its way across to the other side, so I'm not sure what you're talking about there...
Re: Top Layer
Posted: Sat Feb 21, 2015 8:46 am
by tonyno
I've only seen this happen when there are internal features on the top layer.
Re: Top Layer
Posted: Sat Feb 21, 2015 12:19 pm
by mikeysmailbox
Hi
will try the slowing down the Solid infill underspeed.
Yes there is multiple cutouts on the top layer that it fills in different areas at different times and just does not start from one end to the other.
