JoeJ wrote:The Mingda printer lists their software as being compatible with other open-source slicers, so I imagine it would also accept Simplify3D gcode.
Looks like that's the case, I emailed them about using Simplify3D and this was their reply -
"Yes, our 3D printer is also compatible with G-code, so you can use the simplify3D software to help with your work. (Normally, we use CURA software for slicing)"
Good profile for Mingda Glitar 6c,,,For different model only change printing volume( Hight of print ) ,,If you need firmware,display drivers or Win drivers be free to ask,,
